i'm trying to get vista to connect to my n95 via bluetooth to my pc and i keep getting cannot authenticate your phone message anyone help???
bluetooth (vista)
waffabix wrote:i'm trying to get vista to connect to my n95 via bluetooth to my pc and i keep getting cannot authenticate your phone message anyone help???
I get this too from my Vista Ultimate x64 desktop, so you are not alone.
However, I have no problems using the built-in BT on my HP laptop running Vista x64 Business.
Mr G
It's all to do with PC Suite 6.82 not being fully vista compatible. The software messes with the either the Microsoft BT stack or uses the manufacturers one by default which blanks out this option in the software. Toshiba is one that has particular problems (toshiba laptops), whereas others may work ok.
However the PC Suite has just been upgraded to 6.83 and is fully vista compatible and should allow correct BT stack use. Install this, then attempt a BT connect. :icon14:
enigma_uk wrote:It's all to do with PC Suite 6.82 not being fully vista compatible. The software messes with the either the Microsoft BT stack or uses the manufacturers one by default which blanks out this option in the software. Toshiba is one that has particular problems (toshiba laptops), whereas others may work ok.However the PC Suite has just been upgraded to 6.83 and is fully vista compatible and should allow correct BT stack use. Install this, then attempt a BT connect. :icon14:
I'm using v 6.83.14.1 on the desktop .... and it's not working
