NSS and uploading firmware
1 replies · 1,719 views · Started 23 May 2007
Hi Guys (and Girls)
Can I use NSS software to completely wipe the phone and reinstall firmware using my PC and a USB cable?
It seems that the NSS has lots of facilities and capabilities other than changing the product code...
Anyone able to help?
DeanUK wrote:Hi Guys (and Girls)
I believe you can, but i have never tried. Your biggest problem is getting your hands on a copy of the Firmware as it has to be uncompressed onto your PC.
You are far better off just using NSS to change the code then allowing Nokia's NSU to flash to firmware for you.
