Annoying problem with 6630
10 replies · 4,049 views · Started 24 May 2007
Hi
Someone installed anti_theft kind of application on my phone. This application sends one SMS to specified no. whenever SIM is changed or phone is restarted even without changing SIM.
Than he removed the application but phone is still sending SMS .
I tried changing factory default setting it didn't work.
i even upgrade firmware to latest version from Nokia site but nothing worked.
Any suggestions will be appreciated.
Thanx in advance.
Only with correct code or with unlock code buy on software house...
Also, they said, that a firmware upgrade solve the problem.
Here's what you can do: find the name of the app with FExplorer and delete it. If it doesn't work, go to tasks and kill all but the phone and then try again to delete the app. If it still doesn't work, delete some of the needed files for that app, e.g. rsc, dll. You can also try hard format.
I've already deleted the application,
i've forgotten name of the application,
how can i hard format?
i think this will help.
I think the best thing is to format both the phone and the MMC. For details on the hard format, look on the sticky thread on 6600 dedicated forum.
ratza wrote:I think the best thing is to format both the phone and the MMC. For details on the hard format, look on the sticky thread on 6600 dedicated forum.
I've also tried,several times, 3-key combination format. it's not formating rather it is doing as i entered *#7370# i.e. factory default setting or soft format.
i think after firm upgrade it is no longer an option for me!!!
any other ideas how to hard format my phone.
faisalprince wrote:I've also tried,several times, 3-key combination format. it's not formating rather it is doing as i entered *#7370# i.e. factory default setting or soft format.
you can format your phone from settings .. at nokia 3650 you have this option at settings>phone>general>orig phone settings. i think 6630 have the same adress. ..
Open process list with TaskSpy and see if there is any executable running. Search for it and delete it.
i have this kind of problem also.. please help me.. i dont know what to do.. i tried 7370 and everything.. i just keeps sending text message to a desired number.. i cant eve try hard formatting.. please help what to do...
Thank you very much 4 ur reply guys
problem is fixed now
i back-up the phone without files backup
format the phone
and everything is normal as expected
before that whenever i format every time i backed up files too
this time i backed up only contacts+messages+setting+bookmarks
it worked 4 me
