installing maps????????
4 replies · 2,268 views · Started 24 May 2007
iv bort a 1 gb memory card,
iv downloaded the MapLoaderSetup.1.0.w7.02(2) on my pc,
i connected my fone to pc via usb
iv then tried to install the maploader on my phone but nothing appears to happen after iv pressed the download button, does this take ages or something?
if it takes a long time to transfer then il leave overnight to transfer
Some people report long time, but that is not my experience... Try one night, but I�m not convinced:frown:
It took 3 days to get all of the maps of Europe for me on an 8Mbs connection.
It takes a long time.
I found that if you installed direct to the phone via usb cable it took ages.
If you download putting the microsd card into your computer's card reader it installed alot faster. (builtin sd reader in a amd athlon 64 turion ml-44 2gb ram laptop)
I was using a 4mb connection
regards
wayne😊
Pathetically slow..
at least in my experience ..
They really ought to put it on a site with more bandwidth.
