i want a full video on my fone
15 replies · 5,539 views · Started 24 May 2007
how do i put a full video on my fone?
wat gb mem do i have to buy?
wat software do i have to download?
and where do i get the movie from?
:redface: :redface:
kulveer wrote:how do i put a full video on my fone?
:redface: :redface:
First you must have/convert the movie to a compatible format (for instance H264/MP4).
Secondly, the size of the movie depends on several factors; preferred output quality and length of movie.
I use "PS3 Video 9" for conversion which is free and does the job (can be downloaded from www.redkawa.com) and can convert DVD's (*.vob) and other video formats. It has predefined profiles for N95 that are very good.
Use "Nokia 256kbps Small" for viewing on N95. Typical size 90min movie: 250MB.
Use "Nokia 1536kbps Large" for output to TV. Typical size 90min movie: 1.5GB.
As said, you can use it to convert your own DVD's and other video formats. Where you get other movies from but your own will not be discussed here in this forum. How about buying them...?
superswede wrote:First you must have/convert the movie to a compatible format (for instance H264/MP4).
Downloaded .. installed .. looking for the N95 .. not in devices or profiles .. I'll probably edit something .. to get it going .. but be nice to know where you got these "predefined profiles" .. cheers much! 😊
Wirelessly posted (Mozilla/5.0 (SymbianOS/9.2; U; Series60/3.1 NokiaN95/11.0.026; Profile/MIDP-2.0 Configuration/CLDC-1.1 ) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
BanziBarn wrote:Does PS3 Video 9 allow you to convert 16:9 to 4:3 by cropping the sides of the move off?
Yes
Profiles are named "Nokia...", not "N95". Could be that you have to download the patch to get them. I'm on mobile device now so I can't provide link, but there is a patch that must be downloaded. Look in Redkawa forum.
can you convert striaght from dvd disk or do copy the film on the hard drive then convert from there?:redface: :redface: :redface:
superswede wrote:Wirelessly posted (Mozilla/5.0 (SymbianOS/9.2; U; Series60/3.1 NokiaN95/11.0.026; Profile/MIDP-2.0 Configuration/CLDC-1.1 ) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
Hi there,
sorry, but i have searched for this patch, just can't find it. Where did you get it? Maybe even got a link? 😉
Regards,
PM
Go for DivX which you can find here h**p://mobile.divx.com.
You will need to register to download but its totally free, this will allow you to playback virtually any .divx or .avi encoded movie.
I have 2 full dvd movies on my memory card that are each approx 550mb (2gb card) and they play perfectly.
PMitchell wrote:Hi there,
Regards,
PM
The first post in this thread contains links to the updated file which contains the profiles (it's the "Updated File" link you're looking for).
http://www.n95users.com/forum/third-party-apps/1158-ps3video9-video-conversion.html
If you later upgrade/reinstall PS3 Video 9 you must first back-up your profile directory or install this patch after the upgrade/reinstall.
The thread also holds som info and "how-to" that can be useful.
SuperDVD Video Editor is a free software,it's very handy.
Free video editor but much more powerful than so me commercial video editor.
Capture Film form WebCam,DV Camera,TV Card Into Divx or Avi VOB MPEG file format on fly.It includes the following features:
*Edit AVI or Divx VOB MPEG or other format file with the frames control.
*Merge AVIs/Divx VOB MPEG or divide AVIs/Divx VOB MPEG into new file.
*Copy Any Part of the film and save it.
*Divide/Merge Audio or Vedio Stream into new file.
*Change the play speed and add video effect.
*Full Control the Audio and the Vedio streams.
*Direct Burn any format moviesto VCD DVD.
*Extract Movies to Mpeg1 ,Mpeg2,VCD,DVD.
*Support All Media Format in Windows OS.
