Nokia updater
2 replies · 1,499 views · Started 25 May 2007
Hi all,
I am in Canada currently and i got my phone in Hong Kong and i cant update my firmware thru Nokia Updater. My firmware currently is 10.0.018 and i know its not the most up to date one. Can someone help me ?!
oh and i tried using my N95 and pluged it to the tv to watch some clips (avi) with smartmovie. the problem is tat i cant use landscape 1 or 2 to view it da TV cuz its not properly oriented if u know wat i mean. so im left with the last option, which is the portrait mode. Thought that would work but it jus displayed it in da tv as portrait mode. What can i do?! i cant rotate my tv right?! lol but thanks for the help first.
Try opening the slider the other way. If you find a problem watching with slider set to right, then revert it so it goes to left; so that keypad is in view. I have played video relayed onto tv with no orientation problems.
topned wrote:Try opening the slider the other way. If you find a problem watching with slider set to right, then revert it so it goes to left; so that keypad is in view. I have played video relayed onto tv with no orientation problems.
yo thanks man !! 😊😊
