how to mute off the camera of the N73 phone? is it possible?
mute off the camera??
Put the phone into Silent mode. Press and hold #.
lovesign wrote:Put the phone into Silent mode. Press and hold #.
Sorry but not working for me, when i switch to silent mode and press and hold the # button, it only switch to another profile, the vibrating profile, and the sound of the camera is the same
any idea?
No, maybe I wasn't that clear.
Press and hold # to put the phone into the Silent profile. It's quicker than the regular way of switching.
Then try the camera 😊
Any way other than witching profiles?
Not as far as I know.
lovesign wrote:No, maybe I wasn't that clear.Press and hold # to put the phone into the Silent profile. It's quicker than the regular way of switching.
ok, i have changed some time before the name of the silent mode to vibrating mode, and when i press the # button, the phone switch to vibrating profile, but the sound of the camera is all the time the same!!!!!
help plz!
In some countries it's not possible to turn off the camera sound ... for example cellphones shipped to Saudi Arabia and the Arabic Gulf.. you can't turn off the sound of the camera so you don't go on the loose taking pics of girls butts secretly -_- ... i live in middle east ( Jordan to be exact ).. and i can never turn off the camera sound... if you're so desperate , plug in your headset and take shots :P there will be no sound
lenix wrote:In some countries it's not possible to turn off the camera sound ... for example cellphones shipped to Saudi Arabia and the Arabic Gulf.. you can't turn off the sound of the camera so you don't go on the loose taking pics of girls butts secretly -_- ... i live in middle east ( Jordan to be exact ).. and i can never turn off the camera sound... if you're so desperate , plug in your headset and take shots :P there will be no sound
So if i have understand, this is a problem of a firmware?? yes?
can lovesign, tell me wich country code you are using for your update?
any help here?
jawwiste wrote:lovesign, tell me wich country code you are using for your update?
EURO1
thks
