address book conversion [from 7110]
1 replies · 1,464 views · Started 09 January 2003
any ideas how to accomplish this?
the internal 7110 address book lets you tag one user with several records. this is more than can be carried on the SIM.
you can export these records using IR & vCard, but i don't know if this is enough. also, i would have to run up a p800 (which is on order 😞 ) without a SIM to even try this. not something phones seem to like doing.
with the cd software that comes with the 7110 u can transfer the contacts to the outlook in your computer then retransfer them from the outlook to the p800 with the p800 software
