Nokia Application Installer problem (Version: 6.83)
2 replies · 2,930 views · Started 26 May 2007
I have installed latest version of Nokia PC Suite (6.83.14.1) and I have a problem in the Nokia application installer.
In the My Phone section I am seeing the following error message.
"The contents of the currently selected phone model cannot be shown by this application"
Is it really true that N95 is not supported by Nokia PC suite. But I am able to install the files successfully.
Please suggest me if I have to do anything to make the application installer work.
Thanks in advance
- Kalyan
kalyanvgopal wrote:Hi,
Thanks in advance
- Kalyan
Hi K,
I don't have this problem on my N95, so it is probably a dodgy installation of PC Suite on your PC. I can't remember where I saw it, but there is a registry cleaner program that gets rid of old Nokia apps (after you uninstall them all). Try this then reboot the PC before re-installing PC Suite. Hope this info helps?
Dez
Mine also saids that...... but i thought it was normal. If i want to find out what programs i have installed in my N95, i can always open up the menu > applications folder.
Thanks in advance
- Kalyan
