firmware 11.0.026 for EURO-3
Every time I press and hold the right selection key to activate voice dialing, a short tone is played, Speak now is displayed, ... and unfortunately phone reset is executed.
Does anybody have similar experience?
No.... thats scary. I tried the voice activation earlier today a few times and it was fine. I'm also on v11 firmware
I believe you, as nobody else reports such a problem.
I don't know what`s wrong, as I never succeeded in this operation.
When "Speak now" is displayed and progress appears, phone reset is executed every time I try to activate this function.
I'm not sure if it worked on the previous firmware version of my phone.
It may only fail in firmware 11.0.026 with product code 0536074 (EURO3).
Maybe I would have to try firmware 11.0.026 with product code 0534852 (EURO3).
Is it completely the same firmware?
I have found information that the product code is different for various colors of phone. Is it really the only difference?
Results of tests:
- firmware version doesn't matter
- directly after upgrade function works correctly
- unfortunately after restoring backup settings with use of Nokia PC Suite problem appears again
Solution:
- Tools -> Voice comm. -> Settings -> Remove voice adapts.
... and pnone doesn't reset anymore.
