Hi all!
Is it possible to send files on the N70 as attachments with the built-in Messages application using email? When you write an email it only gives the option of sending pictures, music or video, and notes as attachments......!
I would like to send .doc files created in OfficeSuite attached to the email. Is there any way I could do that?
Thanks.
Just send... Is like on other PC. May have only a size limitation, by phone or by network.
beckerbalazs wrote:Hi all!Is it possible to send files on the N70 as attachments with the built-in Messages application using email? When you write an email it only gives the option of sending pictures, music or video, and notes as attachments......!
Thanks.
You can send them from FExplorer. Go to the path where the document was saved and then select Options -> Send -> <mailbox name>
Also possible with the built-in Filemanager (in the "System"-Folder)
