Route 66 on Nokia N91
7 replies · 7,806 views · Started 27 May 2007
How can I install route 66 to my N91? It not works... :con? I have made it several times but it still not work.. :frown:
and I can confirm that... thought not very stable bluetooth connection (from my own experience)
i have it working fine.. no Bt connection problems either...
when installing make sure you have all the files in their right folders...
make sure that the fonts folder isn't in the Apps folder, and make sure you have entered the correct activation code
The people that have it working on their n91, do u guys have a legit copy or dodge one.
i have a dodge one and all i keep getting is "resource error" "resource files are missing"
see my post here..
resource errors are caused by a folder missing or in the wrong place...
you just have to make sure that the maps are in the right place and the fonts folder is also in the right place..
folders should be placed on the phone memory like such
e:\system\fonts
e:\system\apps\route66\maps
e:\system\apps\route66\lang
e:\system\apps\route66\res
e:\system\apps\route66\speech
e:\system\apps\route66\activation.dat
etc etc etc
if they are not in that order they you will get resource error..
