FM Transmitter
4 replies · 11,273 views · Started 27 May 2007
Kind of provolked by the "8 ways to listen to music on your N95 podcast".
Can anyone recommend an FM Transmitter for the Nokia N73?
nj7 wrote:Same thing as N95.About Radio or Music both are the same device.
But the N95 doesn't have a pop connector on it so how could they both use the same?
@lovesign
Thanks but isn't that a more costly way of doing it? Having to buy the Nokia AD-41 to get a 3.5mm jack or is there no other option?
No other option as far as I can tell. The AD-41 didn't cost me that much IIRC. I bought it new from eBay. They are available from as little as £5 + P+P.
The Tunecast II cost me about £20-£25. There is also the AD-46 which is cheaper because it doesn't have the transport controls on it.
