Somebody know how to connect 7650 to a pocket pc ( jornada 545) not for surfing web ( this is ok) but to download photos e upload programs.
Thx
Thx
The IR port should do. Then config your reg. Internet user account at home/work and log in the usual way you should have done. Or just mail the whole thing.
If the IR only works one way (ie from phone to PPC but not from PPC to phone) then you will need to use Peace Maker Pro from www.conduits.com It wont work both ways for me without Peacemaker on an iPaq or a Toshiba e740 but have heard reports that it works fine with other models.
Stezos
I try mbeam and now i can transfer all from phone to pocket pc and i can upload only notes and txt to phone.
Thanks for the help
