😡 OK just got my N95 and im on Vodaphone and most works fine. But i cant get the GPS maps to work. When i click on the item i get a globe up then it auto zooms in and thats it. Any idea. Also i tried to connect to my wireless broadband i entered the key code but it cant connect to it for some reason. It picks it up and thats it. Help needed. My mate got one and hers works fine but she is on another network.
How do I
That's a lot of questions. Most of them have been answered already. Most of them have in fact been answered this week.
If people aren't answering, that's probably why.
For example take a look at several of my own posts here:
http://www.allaboutsymbian.com/forum//forum/thread/60710/
I had similar issues. But I guess guys here must get tired of answering the same questions over and over. So I was very lucky.
But anyway I think you should maybe try searching the forum a little. I'm sure the majority of your questions will be answered there.
Hi Hucker. Have you got maps on your phone? If you have then start up your maps application. let it load, then press select. Go to view, scroll across and go to satellite info. Press select and wait. Your phone could take up to ten minutes for the satellite to pick up. Be sure that your slide is open, and you are stood in a clear area or by the window. The more you use this connection the faster it becomes.
Hope this helps.
