N93 and Smartmovie
5 replies · 4,875 views · Started 28 May 2007
I have been trying to install Smartmovie on my N93. No luck so far. I downloaded Smartmovie, unzipped it then I expected "Application installer to install it. No luck. I have the latest version of PC Suite. I installed another small application just to see if it was something with my PC Suite. It installed OK. I had Smart movie running on my Nokia 6670 when I had it.
Any help for me.
Any error messages? Did you download the S60 3rd Edition version of SmartMovie (the S60 2nd Ed. version will not work on the N93)?
No Error messages, Yes I downloaded the S60 3rd Edition, I thought that when it was unzipped it should automatically start transferring to my phone. It didnt. It just sat there 😊. I tried with PC Suite and Application Installer open and with it closed, but nothing.
You have to also run the installation file (.sis/.sisx) from inside the.zip file.
N/A wrote:You have to also run the installation file (.sis/.sisx) from inside the.zip file.
I have tried that, but it still sits there doing nothing. I think I am going to give up.
Thank you for your time and advice.
Thank you N/A. I have decided to use RealPlayer and it is working, It uses MP4, so now I have to checkout how to convert my AVI files to MP3.
