Popup window onPC
4 replies · 2,029 views · Started 28 May 2007
Each time I connect my n95 to my PC, a popup window appears saying: Found new hardware, Nokia Windows Portable Device Driver. No matter what I do, it keeps popping up. Disconnecting the phone doesn't change it. Any suggestions?
me and my wife both have n95`s hers does exactly the same.... but mine never does!!!!!! we are both on the same firmware V.11 whatever it is!
Hello Jim115, have you tried downloading the latest version of Nokia pc suite from nokia.co.uk this may solve the problem. Let us know how you get on.
Hope this helps.
This means that Windows wants to install the device driver for a feature on your N95 - in this case I think to use it a portable mass storage device. It will go away if you let Windows install the driver or...
...change the data cable mode to PC Suite. You can do this by going to the Connect folder, then Data Cable option. In the case of jim115's post, I imagine one phone is set as mass storage and the other to PC Suite mode.
I also had the same problem.
Go to the Windows device Manager and disable or enable the N95 under 'Portable Media Devices'.
Regards,
PM
