i just buy a NOKIA N76, but it keep restarting when i hear music or use other application...can anyone help me solve this problem!! im using original 512MMC!!!
Anyone can plz help to solve the N76 promblem??
Already answered...
nickly wrote:i just buy a NOKIA N76, but it keep restarting when i hear music or use other application...can anyone help me solve this problem!! im using original 512MMC!!!
try re-formating your phone & then c how it goes.
Reformat cab be done by pressing *#7370# then ph will ask you the security code. default security code is 12345. once you have entered the security code the phone will reformat. during this process the phone will restart itself so dont worry. make sure your battery is full befor reformat
cheers
Hi, Hassan Here...
i baught a new Nokia N76 mobile 2 months back... having the same problem... phone restarts when using music player..... have tried formating... soft reset, deep reset... it seems to be ok for sometime but then again its start its previous behaviour... is there any mobile guru out there who can help me...
u can check firmware version also
lates one could be V31.0.014
