Hello! I have had non-stop issues with my nokia n73 since I got it. I get frequent "memory low -delete some data", "not enough memory to receive texts", and now there are a bunch of blank messages idling in my drafts folder of my text messages which i cannot open nor delete.
Also, it will not let me delete the messages in my inbox, it says "deleting" and then when done they are still in the folder but unexecutable...
PLEASE HELP!
I just ran the update from nokia so my stuff should all be current 😊
Nokia n73 will not open/ delete texts
Hey Guys... It's getting worse, now I have a bunch of messages in my drafts that are blank but will not open and I cannot delete them. Messages are still getting stuck in my inbox as well, and will not open or delete.
Has anyone ever had this happen? It is really getting frustrating!
Thanks for any help you may have
Have you tried SMS accelerator from Nokia support page?
I had some problems with SMS in my phone and it helpped (slowlynes and hang on when sending messages)
Yup, I downloaded that and it fixed the slowness a month or so ago, but now the texts aren't just sending, but now I cannot even open the stuck ones. A couple more build up each day. I can "reply" to them, but after trying to delete them, it's like they aren't really there.
I'm thinking about formatting my memory card, since all the texts are on it.
Just an update: the phone is no longer accepting texts at all, says memory full to everything i try to do even though i dont have anything which should take up a lot of memory, and i cannot even install a task manager because of that.
also, it will allow me to open some texts (but some do not open), and select them to delete, but when i click delete they do not disappear. there are also messages stuck in my outbox now that wont delete...
DOES ANYONE KNOW WHAT MIGHT CAUSE THIS? I'm going crazy...
