Hi all.
I'm using Goosync to synchronise my phone calendar with google calendar and it works greats but what I want to know is if there is a way to schedule this to run on a set schedule (eg/ daily). It uses the built in sync application but I can't find any way to set a schedule, it just lets me manually run it.
Schedule a sync
Would really like to find a solution to this one too! I too use goosync but can't find a way of scheduling a syncronisation - any ideas???
Bump
If you read the FAQs at Goosync, you'll see that that currently automatic syncs are not supported. That would tend to rule out scheduling.
Yeah I was hoping there was something built into the sync tool on the N95 since goosync uses that but I guess I'll just keep doing it manually for now
