Ftp
6 replies · 2,657 views · Started 29 May 2007
Does anybody know if there is a good FTP-client for the Nokia N95?
btw
anybody got a nice torrentpage for symbian apps??
peace
MobyExplorer is, I think, the only ftp client for the N95. In addition, Moby Explorer is Symbian signed. However, there is a bug in the Nokia N95 firmware which means the certificate doen't work, and you can't run the signed version 😡 Bermin Software have notified Nokia of this and it only applies to N95, not any other Nokia S60 ver 3 FP1 or FP2 devices.
So, until Nokia has corrected this, unfortunately the only thing you can do is to run their unsigned version, which I can confirm does work. You just have to press a lot of buttons to let the software access the N95. A chore but it works.
I'm looking for a working FTP client for the N95 since it hit the market (same experiances with MobyExplorer.. a pitty because Moby is a great tool !!! unsigned is not an option... to much of a hassle all these confirmations!!))
Nothing found yet....
:icon13:
mrich wrote:unsigned is not an option... to much of a hassle all these confirmations!!))
Well, as it's the only ftp client, I'd rather press lots of buttons and be able to ftp files rather than have no client. It's a chore but it gets the job done. You just ahve to use a little forethought in getting all files in the right place to ensure a minimum of navigation on the N95 and those confirmation messages every time you change directory.
thats true... so....guess what i haven installed for the time being.... 😉
but for this kind of device it is a bit of a shame to work that way....
chrsfrwll wrote:Well, as it's the only ftp client, I'd rather press lots of buttons and be able to ftp files rather than have no client. It's a chore but it gets the job done. You just ahve to use a little forethought in getting all files in the right place to ensure a minimum of navigation on the N95 and those confirmation messages every time you change directory.
thx guys..! hope there's comin a bugfix from nokia.
another question..
is it possible to connect to my ftp via WLAN?
