Updating N70 to 5.0705.3.0.1
9 replies · 10,712 views · Started 30 May 2007
5.0616.2.0.3 and Nokia pc suite is telling me I should update the phone so I downloaded the update firmware 5.0705.3.0.1 and when I try to update the phone it works fine until it disconnects. Then the update software tells me to take the battery out put it back in plug it in to charge and then turn it on and click "retry" Then it tries again to update it but again the same things.
Any ideas what it could be how can I update the phone when it keeps doing this?
Thanks,
LF-4
On updating to 5.0638 I got a "Connection lost" message, but after removing battery, boot up the phone and connecting it back it worked. Connect the phone to USB before powering on again.
Hm... have you tried *#0000# to see if the firmware was changed or not? If the connection breaks at about 80%, then the new firmware should've been already installed.
Guys i got my phone upgraded!! And its working fine!
I have got
V 5.0705.3.0.1
30-01-07
I updated by downloading "nokia software updater tool" software from the nokia website..
creative70 wrote:Guys i got my phone upgraded!! And its working fine!
I have got
V 5.0705.3.0.1
30-01-07
Can you tell if it works to restore the backup made before upgrade?
Yeah Even I downloaded that and installed it but still its not updating. it just stops when the bar is at like 5% (guessing). I leave it for an hour just to see if its going slow but nothing happens. Maybe its this computer... I never thought of that... ok I am going to try updating it with another one of my computers. Will let you know how it goes.
[Added: 01 Jun. 2007 6hrs after]
Well I used my laptop to update it and it worked. I guess I have a program that is conflicting with the Nokia software update program on my other computer. If at first it does not work. Try another source.
