HELP! Where to find setting for 7650 as modem for laptop?
2 replies · 1,899 views · Started 09 January 2003
If you're dialling out via IR, go to the COnnect Folder and activate the Modem function.
If you dialling out via BT, you will need to use the BT software on your Windowns notebook to dial out using the Dial-Up Networking BT profile. The 7650 will automatically handle everything else, no driver needed.
