finally got tt6 to work and activated key gen etc, cheers dez borders,
so i then debranded and updated firmware, all gone sweet.
i then replace my memory card and it wants a password!!!!!
any ideas, i never gave it a password and dont really want to format and reinstall etc
any ideas
wane
Hi Tanov, try copying your memory card to a folder on your pc. Then put the card in your phone and format it. Then tranfer from your pc back to the card.
this is only an idea to help.
In case the mmc has got pass protected, there's little change the card reader will even read it!
In u cant recall the password, try for matting the card in a S80 device!
done suddenly realised card was my daughters, her name then, easy cheers anyway!!!!
