Problem with DIVX player
2 replies · 2,213 views · Started 30 May 2007
HI I just downloaded and installed 0.87 divx player from divx.org on my new nokia n73 music edition
It comes with two test avi's that I can play if I start divxplayer.
If I find the files via the phones file browser it doesn't know the filetype, and can't start the file.
So now I take one of my own divx files and copies it to the memory card. I open the divxplayer, and chooses files - but I cannot see the file I just copied!
I copied it into the directory where the two test avi's is, namely videos\divxplayer!
Help tells me to scan the phone to add files, but the only scan function is in the mediaplyer, and using that does not add the video file I added to divxplayers file list.
I feel I am missing something really basic here! What am I doing wrong?
thanks
Soren
on the main screen>press #1>Press Menu>Select Rescan file system.
wait till it shows the video on the list.
You have to encode the video with Divx codec b4 you upload it in ur memory card just in case u dont know.
