Problems with Stowaway Keyboard
6 replies · 5,575 views · Started 31 May 2007
Dear All,
I have a stowaway bluetooth keyboard that I used with my old Treo, but for the life of me I can not get it to work with my N95. I have tried all the following:
I have tried to discover it with the bluetooth module, and it will find the keyboard, but when I enter a passcode it does not re-connect to the keyboard and times out.
I have tried using the wireless keyboard app in tool/settings/applications andthis is set ot �auto start � on� and �don�t notify� for new connections.
I have downloaded and installed the N73 driver as mentioned in other threads.
The model number of keyboard that I am using is XTBT01.
Please help!
John
Have you been able to get this to work. I was just considering buying this keyboard. Has anyone else been able to use it on N95?
The above keyboard works fine with the N95 .Follow instructions on stowaway website.(blueooth code on phone first followed by keyboard).
Hi there,
I also have that keyboard and it works so far.
BUT: How do you access:
- Tasks / Menue
- Softkeys
- OK
Buttons?
Regards,
PM
I have been able to get it paired now, but I still get nothing from the keyboard when trying to enter any text from the keyboard. The bluetooth symbol on the main screen does not show a connection, but it is showing up as a paired device in the bluetooth screen.
I also have fresh batteries in the keyboard.
Any ideas?
John
I just got mine and was able to connect it. I downloaded N92 driver and it works - most of the preset keys are working as well. Try doing that and download a user manual from thinkoutside support page, follow the instructions and it should work.
