Print through the PC printer
5 replies · 2,544 views · Started 10 January 2003
Hi all,
do you know if it is possible to print from any 9210 application to the printer of the PC where the communicator is connected (without using the IR but through the serial cable)?
Never tried. The default is IR.
I always move the files to my PC first (usually because I need to edit them in the process) and then print them from there.
Hi Ivan
Please check this link
http://www.greenwichinst.com/Printlinks.html
According to the manufacturer the PC Print should work with the parallel printing adapter GA935-N (by connecting the Serial Cable via the GA935-N to your PC Printer).
Best regards
xuser
I have a HP Laserjet 6p, which has a built in infrared port which is excellent.
Or you get a device mentioned above as well or a printer with the infrared port.
N
Ok thanks, seems like is not possible to do it directly from the serial cable and PC-Suite. I asked about that because i remember that my old Revo was able to print through PsiWin to the printer connected to the PC.
I just thought that Symbian did the same thing with ER6...
Bye
Ivan.
