How to update tomtom to 6.02 and above?
7 replies · 7,453 views · Started 01 June 2007
Im currently on 6.010, when i go to check for updates it says already up to date.
How can I upgrade to 6.02, and when its available, 6.03 for internal GPS
ive checked for updates in the TomTom home software off the CD and direct on the phone and none find any
srw985 wrote:Im currently on 6.010, when i go to check for updates it says already up to date.
Keep checking at w~w~w.tomtom.com/support/support.php?ID=3&Language=1
You can download TT6.02 if you like but unless you have a nokia e61 there's no difference on the N95 from v6.01.
srw985 wrote:So it wont make a difference until v6.03, which has N95 integrated support?
The TT Support website claims 6.02 is for e61 only, so no I would just wait for 6.03 and pray it supports N95 internal GPS receiver.
srw985 wrote:I have on old external GPS anyway, it would just be nice not to have to carry it around
I know, as soon as the N95 internal GPS is supported (and assuming it performs well) I will be selling my TomTom MkII GPS Receiver on ebay.
