E70 VPN Profile
0 replies · 3,709 views · Started 01 June 2007
I'm using the instructions in the 2 following links:
nord-com.net/d.snider/BP_mVPN_PSK_Cisco_1.pdf
66.102.9.104/search?q=cache:0VAyX_SX23UJ:discussion.forum.nokia.com/forum/showthread.php%3Ft%3D80837+NOKIA+USE_COMMIT&hl=en&ct=clnk&cd=2&gl=uk
I have managed to create a SIS file using MAKESIS.exe, however when I try to install it on the E70 I get a certificate error. I have gone into the 'security settings' > 'certificate management' and turned certificate checking off, however its still not installing.
I have downloaded and installed the Symbian 3rd Edition SDK v9.1, and found there is a file called SIGNSIS.exe, which I have tried to use to sign my SIS file, however, I'm not sure what sort of certificate I need to be able to sign. I've create a code signing certificate from our company CA, but that gives a 'File I/O fault, cannot open' I have also tried a standard user certificate, but again that fails. Does anyone have any details, information on signing a SIS file?
Many thanks
Ben
