Help with redkawa please?
5 replies · 1,321 views · Started 02 June 2007
when i use redkawa to convert movie clips so it works on my n95, what is the settings for the encoding profile so it works on my n95, at the moment when i transfer it to my fone it says unable to open movie, will be opened partially, there is sound but no picture.....
im kinda stuck.......
and once uv converted the movie how do u transfer on to a selected device??
:frown: :frown: :frown: :frown:
I actually use Videora ipod converter which is from redkawa not sure if that what your using.
I just use the wizard once done just hook my phone up via usb (coz my card reader wont accept my fancy ultraII 2gb card (sigh) then copy file over.
Crispy
do i then have to download any other software the n95 for the clip to play? is it ok to use real player???
cheers crispy duck. using the ipod format works a treat, do you know any downloadable movie sites
:icon14: :icon14: :icon14:
Glad to help
As for movie sites not really looked. Just used the ipod converter to scale down the file so i can put music videos and a few movies from my DVD collection.
