I can not sync the Phone with Windows XP, I can not even to connect the phone to the PC, I have tried MANY TIMES, please find attached the details :
Hi I have a Notebook :
- Sony Vaio SRX88 with Windows XP Pro SP1
- The USB Base for SE P800 connected to a USB port
- I have installed the USB drivers from the CD ( \Drivers )
- The device is : USB Cable DCU-11 (COM3)
- The driver is SusTeen 1.6.0.2, 10/21/2002
- I have installed PC Suite for SE PE800
- When I select in the mRouter icon the Link Properties
- Connection : USB
- COM Port : COM3
- I get the following error :
"It is not possible to enable the port, as it maybe in use by another application"
I have installed, re-installed, un-install the application and drivers many times ( at least 10 ) and there is no way to make it works, please your advice how to proceed, thanks
