parrot phone kit
2 replies · 1,843 views · Started 02 June 2007
hi,
I have n80 which i want to use with my parrot bluetooth kit in my car but i cannot get the address book ti sync up with it.
can this be done or am i doing somthing wrong.
any help would be great
:con?
The Parrot will not auto-sync your phonebook. You will have to manually send all your contacts to the Parrot. Go to contacts / options/ mark / mark all. Then options / send business card. The phone will then take a while to convert all your contacts for sending to the Parrot, select the Parrot from the list of devices when it pops up and your contacts will be sent to the kit.
HTH
There is actually a prog on the Nokia website, for the 810 that works for the N80 as well and will allow you to sync your phonebook automatically.
It worked for me but I have since stopped it syncing every time as I don't change my contacts often enough.
http://europe.nokia.com/A4143881
Hope this helps
