Hi folks i was wondering if there is a way to tap in to the n95's gps system and then turn that in to a bluetooth gps so i could use it with another device.
Any help appreciated
cheers
Scott
cheers
Scott
scotjen1 wrote:Hi folks i was wondering if there is a way to tap in to the n95's gps system and then turn that in to a bluetooth gps so i could use it with another device.
I see no reason why a programmer could not write an app to read the Internal GPS data then send it down a Bluetooth data connection.
The problem is finding someone with the skills to do it. (I can't program for Symbian OS.)
Its hard to do. From my understanding, the Locations API (the only interface that can talk to the internal GPS) does not produce direct NMEA codes that can be "broadcast" back out through BT. You would then have to emulate the NMEA codes somehow for this to work.
bchliu wrote:Its hard to do. From my understanding, the Locations API (the only interface that can talk to the internal GPS) does not produce direct NMEA codes that can be "broadcast" back out through BT. You would then have to emulate the NMEA codes somehow for this to work.
I strand corrected, it would be quite difficult - but presumably not impossible.
