can't play MIDI anymore
3 replies · 2,361 views · Started 03 June 2007
Hi guys, I have problems with my N3230.
I have installed many themes, apps, and games to my MMC (1GB). But I can't play MIDI files anymore 😡 . It says "Unknown File Format" from the File Manager, and "No related application installed" from SeleQ.. When I changed it to default MMC (32MB) I could play it.
I have already restored factory settings but it didn't have any effect.
What can be the problem? Should I reformat my MMC?:con?
Please help me..
Thx
Copy all the stuff from MMC to PC, format the MMC inside the phone and then copy your files back to MMC.
Was this helpfull to you... Did it solve your problem... I have the same problem with my 7610😡 I've tried to format MMC few days ago and it didnt solve the problem... Then I tried to format phone with "hold-3-key", but still havent fix the problem... I think my next option is to delete every app, theme, game etc. from my card, than repeat the format, because I think that some of the installed apps caused this to happen with midis:con? :con? :con? ...
If you have found solution, please post...
Cheers🙄
There is no need to reformat your mmc.
what I found out:
1. Open your fileman or seleQ. Go to your system\recogs in your MMC drive (ex : "E:"😉. And delete PTBoot.mdl files.. Try it first.
2. I've also deleted Phone Themes folder in System\Apps because I thought PT stood for Phone Themes..
That's the way out of the problem..😎
I don't really know why Themes can have such effect on MIDI..:con? :con? :con?
