P990i - is it worth buying now?
5 replies · 5,291 views · Started 03 June 2007
I need a smartphone which will be used for the following,
1. Occasionally take pictures (feature considered desirable).
2. Listen to music frequently (using headphones).
3. Have long conversations (sometimes stretching to 3 hours).
4. Occasionally browse the web (feature considered desirable).
5. Again occasinally read/edit docs.
6. Messaging - not too frequently.
I have read a lot on the net about the different smartphones. I have finally narrowed down to the sony p990i. Is it worth buying now(considering that Sony has stopped production and will support it only till the end of this year[firmare upgrades]) at a price of Rs.19,000($463)?
Also since it does not support EDGE, will this affect browsing the web?
Can anyone suggest some alternatives to the p990i?(Ones with the same feature set)
I have also read a lot about the poor performance of the p990i. But read somewhere that the new upgrade has made performance better. Can some throw some light?
Thanks to all.
Definitely not - save your money.
I will NEVER buy SE again - the P990 looks good on paper but it never performed. Even after the recent firmware upgrade I was still getting out of memory messages, pathetic.
Above all, it just never sync's accurately with a PC, so important for a small device these days. If you read these pages, people keep talking about possible improvements to Symbian/UIQ, e.g. including smart searching in the contacts app. Why can I only search on surnames? Windows Mobile does it all here and now, why wait for Symbian?
Yes the P990 has it's problems but my opinion is very different to the above.
The camera produces respectable results in most daylight conditions. The flash/light isn't great though and pictures suffer in the dark.
Reproduction through headphones is pretty good. The player is straight forward and may miss a few bangs and whistles but it does the job. Only real annoyance is that it doesn't support .ogg files.
This may be a stumbling block as depending on your set up and usage the battery life can be quite poor however mine tends to sit in it's cradle for good periods slowly charging away so I don't tend to have any problems.
The web browser is very capable. There's no Flash though and, depending on the sites visited, there are occaisonal out of memory problems.
This all depends on the type of documents. Most straightforward M$ Office documents render well but you do loose some formatting when editing. PDF files are a bit hit and miss, some work well others not. If your looking to heavily edit documents then this isn't the machine for you. The keyboard is good for short notes, emails, etc and while creating pages of documents is possible it is not really practical.
SMS and emails (if short) run happily. The only problems I've had is that bluetoothed files are handled by the messaging app and receiving large files seems to cause messaging to hang sometimes. If IM is your thing I believe there are apps out there but I've never used them.
I'm on a contract phone so I'm behind on the very latest versions but the updates that are available have dramatically changed the reliability and usefulness. For me it does what I need it to do and it does it well so even if there are no updates beyond the end of the year I will quite happily stick with my P990i for the next couple of years regardless of what comes along.
Hope this helps
Adam
hammera wrote:The only problems I've had is that bluetoothed files are handled by the messaging app and receiving large files seems to cause messaging to hang sometimes.
Not wanting to completely hijack this thread, but your post made me a little curious! So when someone sends you a file via Bluetooth, the P990i accepts it through the messaging application? How big of a file typically causes the messaging application to hang? Where do the files go after the messaging application receives them? For example, if I were to send an MP3 from my computer to a P990i via Bluetooth, what would happen?
3 & 4 mb files have never caused me a problem but 10+mb have in the past when sent over bluetooth. The files transfer but don't appear in messaging until after a reboot.
Doesn't occur when connected on bluetooth to the PC suite though (uses a different protocol I think).
Thinking about it though that was 2 firmwares ago so maybe the problem has been fixed and if it hasn't then todays news means that it never will be :frown:
Adam
Its a great phone, unless you plan to use it to browse the web, in which case it is a piece of trash. Half the websites I go to get the error "HTML parsing failed".
Since I got this phone 3 weeks ago I have spent 11 hours at my service providers service center and at Sony Ericsson's service center. Phone was replaced (with an older unit actually) but the replacement had the same problem and now it is again being referred to their technical.
