personal lisence key
17 replies · 5,218 views · Started 04 June 2007
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia N70/5.0616.2.0.3; 9399) Opera 8.65 [en])
ratza wrote:
ab_shaiju wrote:while i am trying to use smartmovie then there is asking one personal lisence key, please advise.
Why don't you use DivX Player instead? It's free.
or just do a brief google and find the binpda cracked version!
damo666 wrote:Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia N70/5.0616.2.0.3; 9399) Opera 8.65 [en])
I will never understand why would you search for a cracked/haked/keygen for a commercial software when there is another one available for free and it does the same thing.
i think smartmovie is much better than divx player...on another note, freeware is normall crap(as a rule)...why pay for stuff when you can obtain it for free?btw. I couldn't care less if i was banned from this mundane forum...it's scarcely used anyway.best regards.
So you say that freeware is crap as a rule... Well, here is some "crap" which is free and you probably use:
- FExplorer
- TaskSpy
- Opera mini
- Python
- ReadM
- AutoLock
- Guardian
- OggPlay
and so on. DivX Player is still in beta, so it is not released, there's alot of work to do. I really hope that your work will be paid as much as you pay for the applications you use.
Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))
firdausakey wrote:device serial number : 352753017980838
licence key : ?????
plzzzzzzz!!!... this for smartmovie
Lol..On vacation atm, so cannot generate key for you.Go to prodigits.co.uk and request a key for any app/games there. 😉
ratza wrote:So you say that freeware is crap as a rule... Well, here is some "crap" which is free and you probably use:
- FExplorer
- TaskSpy
- Opera mini
- Python
- ReadM
- AutoLock
- Guardian
- OggPlay
Fexplorer is ok, but i use x-plore with keygen which is much better.Rather use cracked handytaskman than taskspy.Yeah, operamini is pretty crap.Would rather use netfront or opera 8.65 cracked.Python is ok.Autolock is shite...Would rather use smartsettings with loads more options.Who needs guardian?Powermp3 is much better than any oggplay variation...So yeah, most freeware is crap like i just submitted.
For such a mundane place,you still come here and spend time here.......so who's the Mug then :tongue:
Correct..I spend a substantial 10 to 15 mins per day/every other day here!
ratza wrote:It seems like you're just a boaster with your cracked apps.
I think your right there mate,but anyone can get cracked apps it's not that hard.
mr g wrote:I think your right there mate,but anyone can get cracked apps it's not that hard.
I know it is not hard, but I don't get the point; why would somebody use commercial apps when there are freeware which can do the same thing? :hmmmm: Using freewares and contacting the developer makes software better and better. But it seems like it's easier to use cracks.
ratza wrote:I know it is not hard, but I don't get the point; why would somebody use commercial apps when there are freeware which can do the same thing? :hmmmm: Using freewares and contacting the developer makes software better and better.
Exactly mate :icon14:
