Hi can anybody tell me how to close all running applications on the N73 ? And is there any software you can download for this ?
Hope to hear soon with help on this.
Regards from Brian
Regards from Brian
I use Task Manager, or just press and stay Menu key. A list appears, and is enouth press C to close that open application.
Hi just tried that and works, many thanks for that, also did you download task manager from here and is it a good application?
Brian
I think the task manager is a best application for this job. I download from other place.
Regards
popaj wrote:I use Task Manager, or just press and stay Menu key. A list appears, and is enouth press C to close that open application.
just was about to ask the same question, but got the answer 😊
thanx
hi to all thank u very much for this
i am suffering with this problem from the first day itself when i brought the N73ME
😊 thanking U😊
