Hi
Will Smart2Go work on the e60 and which compatible version should I download as the only options are:
e61
e70
n73
n80
n95
Thank you!
Hi
e61
e70
n73
n80
n95
Thank you!
I think that N73 version will work, as it haves the same screen resolution and the same orientation (portrait).
