Anyone got an ogg player working on n95?
OGG files on n95
I can't vouch for how good it is but ALON MP3 Dictaphone is reputed to support OGG music files.
google for "ogg player symbian" and try the first result.....
randomfan wrote:google for "ogg player symbian" and try the first result.....
Does it work on the N95?. It is not explicity mentioned there.
The Series 60 V3 version will work.
randomfan wrote:The Series 60 V3 version will work.
When I try to install it it says "certified is over" (or similar I'm translating but definitely related to the certify). What's happening?.
BTW: I'm installing the mcNuOggPlayQVGA.sis file
Note: I answer my self: http://sourceforge.net/forum/forum.php?thread_id=1717060&forum_id=294909
Uff!. Too complicated. Any other ogg player for the N95?
Try setting the phones date to before 2006, install it, then set the date back. Works for some apps with expired certs.
I've just realised there is another OGG player - Lonely Cat Games' Jukebox. If this is as good as Profimail, it should be a good bet.
OggplayS60_1_70.SIS not supported!
