Syncing Automatically
3 replies · 2,106 views · Started 06 June 2007
I had my N95 set up to sync automatically everytime the bluetooth connected, and I did not have to allow it on the phone. For some reason this has stopped and for the life of me I can not find where you allow automatic connection.
Where is it?
Thanks,
John
If you mean the 'not having to authorise' bit. Go into the bluetooth settings on the phone and go right into 'paired devices'. If you haven't already, pair the device to your pc by using options > pair new device.
Once that's done and the device shows in the paired list, select it and go options > 'set as authorised'.
This allows communication between the devices without asking you.
On a similar note, when the phone is connected via USB, is it poss to get the phone and PC to Sync continiously?
