Hi - I need to connect my E62 to my win32 laptop and get some screen shots of some of the software running on the E62. What suggestions do you have for doing this? Thanks.
Need E62 screen shots
am not sure if i understood your question corectly...but screen shots has a folder called screen shots in your image folder......you can take as many screen shots of sofwares running whihc get saved into the screenshots folder ....and transfer them to your laptop.....or wherever it is..that you want....
dont know if the advise helped....
The software is called ScreenShot and it's freeware. Download it from AAS software section.
Geez, this is my 1,000th post.
