E50 hot-swappable memory card problem
2 replies · 3,746 views · Started 06 June 2007
if I take the micro sd card off E50 when power is on, is the theme installed in memorycard operating well at that moment? can i use the phone before i put the micro sd card back?
thank you for help.
jasonwang wrote:if I take the micro sd card off E50 when power is on, is the theme installed in memorycard operating well at that moment? can i use the phone before i put the micro sd card back?
thank you for help.
1) If your phone is switched on, you must launch the Memory application and Choose Remove Memory Card (or press the power button and chose Remove Memory Card from there) before removing your card or you risk loosing data.
2) If you are using a theme that you have installed on your memory card, when you'll select Remove Memory Card the phone will revert to the default theme. If you want to keep using your custom theme even when the memory card is not in the phone, install it in the phone memory.
3) You can use your phone without the memory card inserted. Of course, you won't be able to use any theme or application that you have installed on the memory card (they won't even appear in the menus until you insert the memory card again).
