I got the wireless working fine on my WPA network at home, but at my girlfriends there is a wireless network (WEP) enabled, it accepts the key but when trying to connect i get
"Shared key authentication required"
anyone shine any light?
sounds like you've just got the key wrong or set the AP type wrong on the phone. nothing wrong with the nokia
key is right though as its the same for all the pc's in the house, they work fine...
dazzyboi84 wrote:I got the wireless working fine on my WPA network at home, but at my girlfriends there is a wireless network (WEP) enabled, it accepts the key but when trying to connect i get"Shared key authentication required"
What brand of router does your GF have? Could she set it to use WPA/PSK?
When I used to own an N80, my Netgear router would only allow the N80 to connect using WPA/PSK. I never managed to get WEP working.
Changed to WPA and works fine...thanks
