7610 Keypad - very odd problem
2 replies · 4,832 views · Started 06 June 2007
I took my 7610 camping with me, and it worked brilliantly until one night it rained and the phone got slightly damp. Still working perfectly however. I realised a few days later that the 6 button was no longer working!
Other buttons also intermittantly stopped working and this was solved by hitting the phone on a hard surface. The 6 button however, is refusing to work.
Is there something I can do, possibly to try and remove the moisture or just replace the keypad? Is that do-able?
:con?
Dismantle the phone and let it to dry itself. Hopefully the keyboard controller was not damaged.
