E90 and microSDHC..
6 replies · 6,008 views · Started 06 June 2007
The title says it all. Does the E90 support the new 4GB microSDHC cards? It has been pretty well confirmed that the N95 supports HC cards and that you can format you cards in either FAT16 or FAT32 on the phone. Does the E90 have this option?
The price of 4GB cards just dropped 30% here in Norway.
khoolhandz wrote:But I may be wrong.
Yes the E90 supports this new standard, link below
The following memory cards are compatible with your Nokia E90. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Nokia E90 accepts Micro SDHC cards. The largest Micro SDHC card you can use in your Nokia E90 is 4096MB
