Gallery button local memory only
4 replies · 2,393 views · Started 07 June 2007
Recently bought an N73 and the later a 2gb kingston mini SD card.
All working fine etc, camera takes photos, music can be played, card recognised etc but when use the gallery button on the side all I get is 6 built in pictures which are on the phone memory and not the SD card. I can't find an option for it to use/search the SD card, is there one, where is it if so?
I can use file manager and browse to photos fine, it's on the latest firmware as I ran the Nokia update.
Have seen the same problem on another forum, though it even could be you.. anyway have you tried to:
- shut your phone off and on
- is your phone having problems seeing the sd-card (sudden messages with: do not remove card etc) you could try to ticken the back of the SD-card with some medical tape (small piece)
- Do you have the latest firmware?
- when you are taking a picture, does the phone store them on the card?
Good luck!
Phone has been rebooted several times.
No problems with SD Card whatsoever, like I say vids fine, music fine.
Latest firmware installed
Photos go straight to memory card as normal
No one?
I found an option when using the camera to save to an album. Via the image/gallery button I created an album, took a picture but when I go back into image/gallery it asks me to create an album like there isn't one there on the system.
but... I can add a picture to album and it'll show the name of the album but I cannot access it.
