calendar holidays
3 replies · 2,375 views · Started 10 January 2003
I was disappointed to find out that my P800 does not indicate public holidays in the calendar, and called the SE support who confirmed this and said the only hope is 3rd party developers. Can't neleive this is not a standard item, since we all need to know when the public holidays take place.
Is there any such out there that are writing public holiday indications for Sweden?
I believe you answered the question yourself in the last comment... I assume the problem is that a lot of the holidays differ from country to country, so SE would have to implement a whole lot of different calender versions... For example, I'd like to use english menus (as the translations often have a tendency to be wrong), but if I wanted public holidays, I wouldn't want the english ones...
I have not tried this but if your OUTLOOK contained the holidays would not a sync betwen the two then update them on the P800.
I am sure you can find the Holidays for you country for OUTLOOK someware.
I just a quick look and found the following link its not for your country but that is the kind of thing I am talking about.
http://microsoft.com/downloads/details.aspx?FamilyID=7d4d9017-8d4e-4963-8ba7-d2e91d491f5e&DisplayLang=en
Sorry I dont have a P800 yet so can not test it or know if this would work.
Actually, I've just installed it in my Outlook and it shows a massive list of Countries to choose the holidays from! Fantastic!
Now I just need to get my P800 when in finally makes it to the UK... 😃
AL
