That damn alarm keeps wakin me up!
2 replies · 3,094 views · Started 07 June 2007
Can anyone tell me why my alarm goes of about five times, i have only got it set once. It goes off i turn it off then another one immedietly goes off and so on.. I got a feeling that it might be when i change a theme, not sure. Orange could not help, apart from telling me to reformat it. I have tried and checked everything! heeeeeellllp need me sleep!!!😮
same problem with me. even after turning off the alarm , the little bell does not disappear and alar goes on every morning .................
frustrating
I don't know if you have already solved your problem. The case is, the little bell does not disappear because you have some alarm active, this is in Tools->Hour. In my case, I see three alarms and have only one active at 7:15 am which goes every morning, I think this is by default, but you can set the repeat option to another one difrente than "daily". Hope this help
