do i need to work on my n80 please? and any places i can get it?
cheers folks
which version of tomtom
Go to the Tomtom site.
got a version 6 but from reading on her i have to change my firmware, how do i tell what version i have on the phone to start with please?
on the standby screen, type *#0000#
i have V4.0707.0.7 and tomtom 6 works fine
mcmental wrote:do i need to work on my n80 please? and any places i can get it?
cheers folks
My tomtom works on my N80 V4.0623.0.42
tomtom version
App version 6.010(7640) - GPS driver v1.20 -Maps v650.1046
regards
wacits wrote:My tomtom works on my N80 V4.0623.0.42tomtom version
App version 6.010(7640) - GPS driver v1.20 -Maps v650.1046regards
Did anybody try the following map
http://torrents.thepiratebay.org/3716320/TomTom_Eastern_Europe_v680.1466.3716320.TPB.torrent
It doesn't work with my TomTom version (the same version as quoted above). Maybe there is a problem because I had map with the same name already present.
First I tried to activate this new map and activation was successful, but then tomtom didn't start.
When I delete map from memory card, tomtom was warking with other (WE) map.
When I deleted that map from TomTom (not phisicaly from memory card) new map (680) doesn't show in switch map menu.
Is this map working with current version of TomTom?
Did I do something wrong?
Thanks in advance.
Now with the TomTom you have to have a GPS module as well right? Such as the Nokia GPS module. Or is there only a TomTom module that works with the software?
pretty much any will work, such as the bt-77
yeah, theres a tomtom gps module thread somewhere.
You don't need a GPS to browse the maps. TomTom will start up at your designated home location each time.
But you'll get bored quick without one!
I know on the pocketgpsworld forum a lot of people picked up BT receivers from eBay cheaply.
yeah, I got mine off the bay... its been great.
I think theres a thread somewhere about it...
