Use internet on PC using E70's WLAN - possible?
2 replies · 2,102 views · Started 08 June 2007
As the title suggests, I would like to know if you can surf the net on a PC/laptop with E70's WLAN connection. I've searched for this for the last two days and no results. PC Suite's Connect to the internet only allows a GPRS connection (or?) based on APN, user name and password. So, is it possible or not? If yes, how can this be made?
ratza wrote:As the title suggests, I would like to know if you can surf the net on a PC/laptop with E70's WLAN connection. I've searched for this for the last two days and no results. PC Suite's Connect to the internet only allows a GPRS connection (or?) based on APN, user name and password. So, is it possible or not? If yes, how can this be made?
I doubt that this is possible and given that you can get wifi adapters for your laptop for less than �20, it probably wouldn't be worth the hassle anyway.
